Posted: 2020-07-03 05:04 PM . Last Modified: 2024-04-08 12:20 AM
I have just setup a new StruxureWare Data Center 7.2.7 and Attached a few NetBotz appliances and Sensors to test, I noticed if I plug a Sensor in to Pod or Rack Monitor, then Unplug it (lets just say its no longer required), how do I remove the particular temperature sensor labelled "unplugged".
I noticed you can do "view sensors" on multiple levels in the device view, however the Delete Sensor option is Greyed out.
(CID:120133669)
Hi brenninson,
Unplugged sensors from NetBotz appliances and pods must be removed using APC Advanced View software (see page NetBotz v4.6.2).
Therefore, connect the Advanced View software to the required NetBotz appliance, where you need to remove Unplugged sensors. Then right-click on the desired Sensor Pod and select Configure Pod... In the Sensor Pod Configuration window that appears, click the Sensors... button. Then in the Sensor Configuration - Sensor Pod window that opens, select the Unplugged sensor and click the Remove... button. Only after this, the Unplugged sensor will no longer be displayed in the DCE-client.
With respect.
(CID:120133728)
Thanks will test it out today and let you know.
(CID:122094810)
All good.
Thanks for your help.
(CID:122094855)
Hi brenninson,
Thanks for the answer, we will consider that the issue is resolved.
With respect.
(CID:122094972)
Hi brenninson,
Tell me, please, have you solved the problem or not?
With respect.
(CID:120134453)
Posted: 2020-07-03 05:04 PM . Last Modified: 2023-10-22 01:52 AM
