Posted: 2020-07-03 04:21 AM . Last Modified: 2024-04-08 11:41 PM
For reporting, what are the exportable formats? Customer looking for CSV but don't believe that is standard.
(CID:106210323)
Hi Jeff,
When you configure the schedule for an export, you can choose the format. I believe the default is comma delimited which is the format of a CSV file:
I believe this may still be sent as a .txt file but simply renaming it or opening it in a tool such as MS Excel will allow you to format it in the same manner as a .csv.
If you simply want to save a table report, you can choose a .csv specifically:
(CID:106210328)
Posted: 2020-07-03 04:21 AM . Last Modified: 2023-10-31 10:23 PM
