synchronizeCustomer bombs when ampersand "&" in customer_company
  • synchronizeCustomer bombs when ampersand "&" in customer_company
129
72
Posted: ‎2020-07-03 04:22 AM . Last Modified: ‎2024-04-08 11:40 PM
1044
DCO 7.5 CustomerWebService-V1 : synchronizeCustomer
I can't find a way to load a customer name that has an ampersand (other than replace it with the work "and", e.g. replace "AT&T" by "ATandT", or replace "AB & T Pty Ltd" by "AB and T Pty Ltd").  I tried preceding the & with a backslash but that didn't work either.
Any ideas?
http://schemas.xmlsoap.org/soap/envelope/">
soap:Client
Unmarshalling Error: Unexpected character ' ' (code 32) (missing name?) at [row,col {unknown-source}]: [181,26]
(CID:106210372)
  • Data Center Operation
1043
Normally, you escape & using &
Please try and see if that helps.
(CID:106210397)
1044
(CID:106210397)
Thanks Martin, works perfectly
(CID:106210818)
Posted: ‎2020-07-03 04:22 AM . Last Modified: ‎2023-10-31 11:38 PM
