DCO nfs mount fail
  • EcoStruxure IT forum
  • Re: DCO nfs mount fail
  • Subscribe to RSS Feed
Cory_McDonald
Admiral Cory_McDonald Admiral
110
Jef
Admiral Jef Admiral
104
gsterling
Captain gsterling Captain
70
APC_Steve
Commander APC_Steve Commander
59
Back to EcoStruxure IT forum
orlandogarcia
orlandogarcia Schneider Alumni (Retired)
Posted: ‎2020-11-17 01:56 PM
1481
DCO nfs mount fail
Hi all,
The remote backup configuration video is no longer available.
A customer was trying to mount a nfs to DCO and is getting the following error message:
Failed to save mount : NFS Error - mount: wrong fs type, bad option, bad superblock on xxxx.com:/ifs/USA/NASHARED/struxureware, missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount. helper program) In some cases useful info is found in syslog - try dmesg | tail or so.
Looking at older posts seems like the problem is NFS utility is missing?
  • Data Center Operation
Jef
Admiral Jef Admiral
Admiral
Posted: ‎2020-11-18 01:08 AM
1471
Hi Orlando,
You are right, it seems nfs utility is needed.
SSH log in to server and then run the following command to install the utils (requires Internet access):
sudo yum -y install nfs-utils
Kind regards,
Jef
Replies 3
Jef
Admiral Jef Admiral
Admiral
1472
Hi Orlando,
Kind regards,
Jef
orlandogarcia
Posted: ‎2020-11-23 12:44 PM
In response to Jef
1451
Thank you Jef.
Jef
Admiral Jef Admiral
Admiral
Posted: ‎2020-11-24 12:02 AM
In response to orlandogarcia
You are welcome, Orlando,
Kind regards,
Jef
Terms & Conditions Privacy Notice Change your Cookie Settings © 2024 Schneider Electric, Inc
