84323members
353488posts
DCO Upgrade 8.2.7 to 8.3 failed
DCIM_Support
Picard
Picard
495
This question was originally posted on DCIM Support by Luis Lopez Borbon on 2019-05-21
Hello Jef and DCIM support team
The DCO server was upgraded from version 8.2.7 to 8.3.0 but it failed, and the upgrade logs shows “the upgrade process did not result in a new version of DCO”. I did two attempts… the first one I checked only the option “Do not download packages from internet” and the second try I checked the both options: “no third-party RPM” and “Do not download packages from internet” were selected… both attempts showed the same error and after the server was rebooted, it never changed the DCO version. The DCO log file from the webmin was downloaded, if you needed please let me know how the best way is to share you. Please your support because I have scheduled many customers to upgrade their servers.
(CID:143759990)
9 Replies 9
DCIM_Support
Picard
Picard
Re: DCO Upgrade 8.2.7 to 8.3 failed
This comment was originally posted on DCIM Support by Andrew Trabert on 2019-05-21
I had a similar issue going from 8.2.12 to 8.30, it failed the first time with "do not download packages from internet" checked, but was successful the 2nd time with it unchecked.  I've seen issues with that option not working correctly in previous versions and wonder if it's something similar in this one.
(CID:143760011)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Luis Lopez Borbon on 2019-05-21
Hello Andrew
Thank you for your feedback… Did you get the upgrade success with both options unchecked, right? But my serve does not have internet access…If you do not select the option “Do not download packages from internet", the server will search in the internet some updates… did you get the upgrade successful without internet connection and both option unchecked?
(CID:143760062)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Andrew Trabert on 2019-05-22
Yes, with both options UNCHECKED, the upgrade worked.  I didn't try it a second time or investigate it further.
Only other work around would be to deploy a fresh 8.3.0 VM, then import your backup from the other server.
Hopefully someone else can comment on this with a possible solution.
(CID:143760123)
DCIM_Support
Picard
Picard
495
This answer was originally posted on DCIM Support by Jef Faridi on 2019-05-22
Hi Luis,
It seems you have tried the recommended option by checking the “Do not download packages from internet” for offline installation.
I can take a look at your log files - I will send you an invite to my =S= box shortly, so the data safely can be provided to me, thanks.
However, if for some reason the offline upgrade should fail, then I agree with Andrew that the best option could be to apply a clean 8.3 installation and then restoring the latest backup file.
Kind regards
(CID:143760345)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Luis Lopez Borbon on 2019-05-23
Hi Jef, thanks for your support... I will hope your box invitation to upload the log file.
(CID:143760902)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Jef Faridi on 2019-05-24
Hi Luis,
I have resend the box invite, thanks.
Kind regards
(CID:144311059)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Jef Faridi on 2019-05-28
Hi Luis,
Many thanks for providing the log file - it appears the offline upgrade is failing due to package dependency requirements. (updated packages would have been required, and since we are doing offline upgrade they cannot be accessed).
A similar outcome/issue we have had with some installations recently and have captured a sort of bug report so it can be resolved in a next release version.
For the time being, where the server dose not have Internet access if possible please go with clean installation of DCO 8.3 and then restoring the latest backup file.
Kind regards
(CID:144311678)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Luis Lopez Borbon on 2019-06-07
Hi Jef... thanks a lot for your feedback and recommendations.
(CID:144867649)
DCIM_Support
Picard
Picard
🔒 Closed
