Posted: β2020-07-03 11:44 PM . Last Modified: β2024-04-05 04:50 AM
Hi
Im investigating the REST API (v8.0) and have a problem with the "asset search" operation
https://(some-ip)/api/current/assets/search?q=blade
It is NOT returning all expected results. Is there a limit on the JSON data returned? The JSON result is always around approx max 1150 lines. And that is too few lines/results. I know there is more π
How do I overcome this? Also - i don't seem to be able to finde any documentation on any eventual pagination. Where can I find more info.
Best regards
SΓΈren
(CID:125211050)
Taking the answer from similar question:
Just a note on the GET /assets/search operation: for performance reasons there is a limit to how many elements will be returned. It is capped at 50 items.That is a hardcoded limit that cannot be manipulated at runtime.
Chris
(CID:125211453)
Posted: β2020-07-03 11:44 PM . Last Modified: β2024-04-05 04:49 AM
Please allow the limit to be customized beyond 50.
(CID:128760604)
Datacenters have more than 50 items in them...
(CID:128760607)
We began using ETL instead. Schneider Electric took a good step towards REST, but crippled API to the point that its not ideal to script off of. The old SOAP API was better in my opinion.
(CID:126160751)
Posted: β2020-07-03 11:44 PM . Last Modified: β2023-10-22 01:39 AM
