DCO Delete walls
  • DCO Delete walls
127
65
Posted: ‎2020-07-04 05:04 PM . Last Modified: ‎2024-04-05 12:02 AM
1023
DCO Delete walls
How do I delete walls in DCO? We reconfigured out room and removed some walls. Do I have to completely rebuild my data center floor and all the racks?
I am unable to move the room partitions which were in the old layout.
(CID:130681443)
  • Data Center Operation
Replies 4
1023
Hi John,
I would try to use the Design tool to delete/modify the manually created walls and/or reshape the walls.
An example to delete a wall, Design mode enabled (highlighted with dashed circle) right click on a manually created wall and "Delete" (or modify):
Reshape/modify a wall: using the resize tool, click on a wall and then drag to left/right to move the wall:
And/or "Add Corner"and then reshape the wall:
Hope this helps,
Kind regards
(CID:130681533)
The wall you are referring too is an "interior" wall, right? The one highlighted blue in the first image?
I originally used an exterior wall, extended into the DC Floor. When I try that delete button, it prompts me if I want to delete the whole floor...
(CID:131336559)
Hi John,
Yes, that was an "interior" wall (which had been created manually). (first illustration/image)
The "exterior" walls, which are not created manually, cannot be selected for delete, but can be reshaped (my last illustration/image).
Kind regards
(CID:131336567)
Posted: ‎2020-07-04 05:04 PM . Last Modified: ‎2023-10-22 01:36 AM
