Posted: 2020-07-04 05:03 PM . Last Modified: 2024-04-05 12:02 AM
I am upgrading DCE to 7.4.3 prior to 7.5 the file uploads ok, and when I get halfway through step 1 the DCE fails to respond and throws up this screen
Once I restart the VM it runs ok but will not complete the upgrade. Has anyone else come up against this issue??
TIA
Mike
(CID:130681344)
Dear Mike,
Please take a look at the below K-base document which has got a fix for your issue.
https://www.schneider-electric.co.in/en/faqs/FA290375/
First, you need to verify if you have enough storage on your DCE under Administration Settings-Storage. If it is only 4GB, then you need to consider increasing it before attempting to upgrade.
I have posted a tip on how to increase the storage of DCE. Please refer the same.
Procedure to increase storage for the DCE virtual appliance on VMware
I hope this helps.
Bala
(CID:130681355)
Dear Mike,
I hope this helps.
Bala
(CID:130681355)
If what Bala mentioned does not help, please consider this FAQ as well: http://www.apc.com/us/en/faqs/FA333354 - StruxureWare DCE “Unable to retrieve data from server. Attempting to connect…” message received
(CID:130681395)
Posted: 2020-07-04 05:03 PM . Last Modified: 2023-10-22 01:21 AM
