Posted: β2020-07-05 12:34 PM . Last Modified: β2024-04-04 12:49 AM
While performing a fresh install of DCE 7.4.3 the installation hangs at "anaconda installer init version 13.21.229 using a serial console" it does not move past this stage to continue installing.
(CID:134681440)
Dear Ryan Reid,
In order for you to be helped faster and better, please specify the type of equipment to which you tried to deploy the DCE-7.4.3 restore ISO-image.
In addition, I highly recommend that you try to do the same with the latest version of the .
With respect.
(CID:134682248)
I was able to make a bootable DVD with the ISO then it was able to fully install.
(CID:134682600)
Ok, very thanks for the good feedback π.
(CID:134682644)
Posted: β2020-07-05 12:35 PM . Last Modified: β2023-10-22 01:25 AM
