DCE firmware 7.6.0 BUG
  • EcoStruxure IT forum
  • DCE firmware 7.6.0 BUG
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 01:40 PM . Last Modified: ‎2024-04-04 12:26 AM
1547
Hi Support,
I updated DCE with new firmware and faced with bug.
I cant add,edit or delete Virtual Sensor any more.
All sensor what were on previous version are there and OK, but new I cant add.
Does anyone have same issue?
Best Regards
Stanko Markovic
(CID:134693093)
  • bug
1547
Hi Stanko,
I would not consider this a "bug" as that would indicate it is an issue with the feature itself and a failure of the actual code.
I'm running DCE 7.6 and I have no issue creating or manipulating virtual sensors.
Have you rebooted the server again?
Have you tried a different client system?
Have you tried a different user?
How long ago did you upgrade? If it was just recently, do you have a backup of the old system and can you restore back to 7.5 or whatever version you were and and verify it is working then try the upgrade again?
As I mentioned, it doesn't appear to be a failure in the way it was designed (bug) as I'm not seeing the issue so there's something more specific about your environment that needs to be troubleshot.
Steve
(CID:134693109)
Replies 4
1548
Hi Stanko,
Steve
(CID:134693109)
Hello Steve,
I tried in friday to create virtual sensors during internal training.
Today, I can see there are all virtual sensors present. I didnt reboot server neither client app. My server needed more then 1h to create sensors?!
You are right, its not bug. But I`m wondering, why it took so long?
Best Regards
Stanko
(CID:134693700)
Hi Stanko,
I couldn't say. Possibly it's a communications issue between the server and client(s), possibly the resources the system has is not enough or was being used for other processes at the time, I can't say. Next time I'd suggest possibly rebooting the server if you'd not already done so, try another client, If it's a VM, increase resources potentially.
Steve
(CID:134693707)
Posted: ‎2020-07-05 01:40 PM . Last Modified: ‎2023-10-22 01:24 AM
