DCE & DCO Linux client installation procedure
  • EcoStruxure IT forum
  • DCE & DCO Linux client installation procedure
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:22 PM . Last Modified: ‎2024-04-08 12:59 AM
1093
Hi team,
One of our Clint having red hat Linux for client installation. They have downloaded the linux client from DCE & DCO web client.
How to install the thick clients. Please provide the DCE & DCO thick client installation procedure.
Thanks & Regards
K.Venkat
(CID:116922651)
  • Data Center Operation
1093
Hi Venkatasubramaniam Krishnamurthy, hi team,
Concerning the installation of DCO-clients on Linux PC, I have the following remarks:
  • the current DCO-clients are only for Linux x86_64;
  • DCO-cliens do not require any separate installation procedure, you just need to unpack the tarballs into the right folder and all;
  • unfortunately I still have not been able to successfully launch any of the three DCO-clients on CentOS-7.3. The reason is the common error "JVM terminated .Exit code = 127".
For example, errors from launch DCO-client:
bashStruxureWare Data Center Operation-8.1.0 errorsJVM terminated. Exit code=127 /home/admin/StruxureWare Data Center Operation-8.1.0/jre/bin/java -Xms256M -Xmx768M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+CMSIncrementalPacing -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=utf-8 -DbuildType=release -Dosgi.bundlefile.limit=0 -DsyncProduct=OPERATIONS -Dosgi.nls.warnings=ignore -DSWT_GTK3=0 -jar /home/admin/StruxureWare Data Center Operation-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -os linux -ws gtk -arch x86_64 -showsplash -launcher /home/admin/StruxureWare Data Center Operation-8.1.0/StruxureWare Data Center Operation -name StruxureWare Data Center Operation --launcher.library /home/admin/StruxureWare Data Center Operation-8.1.0/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so -startup /home/admin/StruxureWare Data Center Operation-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar --launcher.overrideVmargs -exitdata 20d0007 -application com.apc.isxo.client.bootstrap.application -clean -vm /home/admin/StruxureWare Data Center Operation-8.1.0/jre/bin/java -vmargs -Xms256M -Xmx768M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+CMSIncrementalPacing -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=utf-8 -DbuildType=release -Dosgi.bundlefile.limit=0 -DsyncProduct=OPERATIONS -Dosgi.nls.warnings=ignore -DSWT_GTK3=0 -jar /home/admin/StruxureWare Data Center Operation-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
And errors from launch DCO Insight-client:
bashStruxureWare Data Center Operation Insight-8.1.0 errorsJVM terminated. Exit code=127 /home/admin/StruxureWare Data Center Operation Insight-8.1.0/jre/bin/java -Xms256M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+CMSIncrementalPacing -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=utf-8 -DbuildType=release -Dosgi.bundlefile.limit=0 -DsyncProduct=REPORT_DESIGNER -DSWT_GTK3=0 -Dorg.eclipse.swt.browser.DefaultType=ie -Dorg.eclipse.swt.browser.IEVersion=9999 -jar /home/admin/StruxureWare Data Center Operation Insight-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -os linux -ws gtk -arch x86_64 -showsplash -launcher /home/admin/StruxureWare Data Center Operation Insight-8.1.0/StruxureWare Data Center Operation Insight -name StruxureWare Data Center Operation Insight --launcher.library /home/admin/StruxureWare Data Center Operation Insight-8.1.0/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so -startup /home/admin/StruxureWare Data Center Operation Insight-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar --launcher.overrideVmargs -exitdata 2110007 -application com.apc.isxo.client.bootstrap.application -clean -vm /home/admin/StruxureWare Data Center Operation Insight-8.1.0/jre/bin/java -vmargs -Xms256M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+CMSIncrementalPacing -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=utf-8 -DbuildType=release -Dosgi.bundlefile.limit=0 -DsyncProduct=REPORT_DESIGNER -DSWT_GTK3=0 -Dorg.eclipse.swt.browser.DefaultType=ie -Dorg.eclipse.swt.browser.IEVersion=9999 -jar /home/admin/StruxureWare Data Center Operation Insight-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
And errors from launch DCO Lab-client:
bashStruxureWare Data Center Operation Lab-8.1.0 errorsJVM terminated. Exit code=127 /home/admin/StruxureWare Data Center Operation Lab-8.1.0/jre/bin/java -Xms256M -Xmx768M -Xss4M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+CMSIncrementalPacing -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=utf-8 -DbuildType=release -Dosgi.bundlefile.limit=0 -DsyncProduct=DATA_CENTER_LAB -Dosgi.nls.warnings=ignore -DSWT_GTK3=0 -jar /home/admin/StruxureWare Data Center Operation Lab-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -os linux -ws gtk -arch x86_64 -showsplash -launcher /home/admin/StruxureWare Data Center Operation Lab-8.1.0/StruxureWare Data Center Operation Lab -name StruxureWare Data Center Operation Lab --launcher.library /home/admin/StruxureWare Data Center Operation Lab-8.1.0/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so -startup /home/admin/StruxureWare Data Center Operation Lab-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar --launcher.overrideVmargs -exitdata 2130007 -application com.apc.isxo.client.bootstrap.application -clean -vm /home/admin/StruxureWare Data Center Operation Lab-8.1.0/jre/bin/java -vmargs -Xms256M -Xmx768M -Xss4M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+CMSIncrementalPacing -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=utf-8 -DbuildType=release -Dosgi.bundlefile.limit=0 -DsyncProduct=DATA_CENTER_LAB -Dosgi.nls.warnings=ignore -DSWT_GTK3=0 -jar /home/admin/StruxureWare Data Center Operation Lab-8.1.0/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
Someone from the expert has useful tips for solving the above problems?
Very thanks for the support.
(CID:116923346)
Replies 5
1094
(CID:116923346)
Posted: ‎2020-07-03 03:23 PM . Last Modified: ‎2024-04-08 12:59 AM
Practical recommendations for installing the DCE-client on modern Linux, I wrote on the link
And about the installation of the DCO-client under Linux, I found only , and it's true for DCE-7.5 unfortunately. I think, that soon I will be able to write practical recommendations for installing the DCO-client on modern Linux for the current version of DCO-8.1.
With best regards.
(CID:116923748)
SOLVED: The reason is above the indicated error -- incorrectly downloaded three tarballs (directly from the DCO iso-image). I.e., in these tarballs in the subdirectory jre/bin/java there was only one executable java file. Therefore, after correctly downloading the above three tarballs from a functioning DCO-server, the problem was successfully solved. I.e., in the jre/bin/java subdirectories there was already full JVM installation and all three DCO-clients successfully launched on CentOS-7.
With best regards.
(CID:116923852)
Thanks for your great support.
(CID:116923959)
Posted: ‎2020-07-03 03:23 PM . Last Modified: ‎2023-10-22 01:15 AM
