Posted: 2020-07-05 10:24 PM . Last Modified: 2024-04-03 12:29 AM
Dear support,
After upgrading to DCE-7.7.1, I found the following bug in the web-GUI.
Suppose, after creating a gadget with several sensors of one device in the web-GUI, one or several sensors become in the Unplugged state:
If after that the above mentioned Unplugged sensors are deleted through the DCE-client, then the above mentioned gadget is completely cleared for some reason:
This also causes an error: [500] An error has occurred.
Prior to the upgrade, the behavior of the DCE-server was absolutely correct and predictable. That is, when removing Unplugged sensors, the contents of gadgets were not cleared. Then it was possible to simply edit the gadget in an appropriate way and it was very correct.
Please fix this annoying bug.
Very thanks for the support.
(CID:149291896)
Support case number: 63333885.
(CID:149291978)
Posted: 2020-07-05 10:24 PM . Last Modified: 2023-10-22 01:13 AM
