how to configure DCE to receive SNMP traps from non APC PDUs
  • how to configure DCE to receive SNMP traps from non APC PDUs
127
65
Posted: ‎2020-07-05 10:23 PM . Last Modified: ‎2024-04-03 12:29 AM
1545
Hello team,
I am trying to configure my DCE server to receive traps from my PDU which is from Raritan.
I was wondering if DCE has the option of receiving traps from non APC devices and if so what configuration has to be made on the DCE server except for the SNMP server configuration tab.
Thank you for the help
(CID:149291860)
1545
Dear Gleb Tyunikov,
From your question:
I was wondering if DCE has the option of receiving traps from non APC devices...
Unfortunately, this is still not supported (for non =SE= devices). If you wish, you can write again about this on the web resource Product Feedback.
With respect.
(CID:149291868)
Replies 5
1546
Dear Gleb Tyunikov,
From your question:
With respect.
(CID:149291868)
Thank you for the answer, is there a plan for this feature to be added?
(CID:149291873)
Would be nice if this could be added
(CID:149291885)
I can’t know this, but this topic has been discussed here for a long time (try searching here and you will see for yourself).
By the way, the DCE-server cannot analyze SNMP traps. A DCE-server can only receive SNMP traps from native =SE= devices as simple signals. Then, after the DCE-server receives such a "simple signal", it simply scans the device immediately (without waiting for your turn in accordance with the set scanning interval). Therefore, for your desire to receive SNMP traps from non =SE= devices, this may not be suitable.
With respect.
(CID:149291887)
Posted: ‎2020-07-05 10:24 PM . Last Modified: ‎2023-10-22 04:37 AM
