Posted: 2020-07-05 02:52 PM . Last Modified: 2024-04-03 11:45 PM
I need to ingerate DCE 7.6 with Eco Building Operation v.2.0 and I am gonna follow the procedure in the following link https://community.se.com/t5/EcoStruxure-Building-Operation/Data-Center-Expert-with-SmartStruxure-sol... but I need to confirm the following :
1- No extra Licnese is required for DCE.
2- No extra Licnese is required for EBO.
3- Is there any updated procedure or recomentations that I should follow as the mentioned procedure describes the intergration for DCE v7.2.x and SBO v1.6.
BR,
Sameeh
(CID:137106494)
Sameeh,
I can only answer on the DCE portion.
1- No extra License is required for DCE.
Yes, there is no licenses required to enable EWS in DCE
The SBO/EBO portion, do post to the exchange community to get confirmation whether license is required for SBO/EBO to consume EWS as well as for the upgrade steps & requirements.
(CID:137106534)
Sameeh,
(CID:137106534)
Hi Chris,
Thanks for your relpy.
BR,
Sameeh
(CID:137106783)
Posted: 2020-07-05 02:52 PM . Last Modified: 2024-04-03 11:44 PM
You can integrato with the EWS, follw the instructions:
1 Create a User and password in the DCE
2. Create a new EWS interface in the SBO
3. In EWS serve add the DCE IP Address, Copy: DataExchange/DataExchangeService in the path an d use the user and password create an the step 1
(CID:137727789)
Thank you very much for your reply
(CID:137728111)
Posted: 2020-07-05 02:52 PM . Last Modified: 2023-10-22 01:13 AM
