Posted: 2020-07-03 12:00 AM . Last Modified: 2024-04-09 01:03 AM
Hi All!
I have an issue with mounting windows share for backup restore.
Its my test DCE 7.2.7.25 running on virtual box.
When I try to mount backup location to DCE7.2, I have an error:
If I try to mount this share for backup it mounts succesfully and I can make backup:
There is no errors in nbc logs:
Sometimes when I click Next several times DCE open "Restore From Backup" window, but with no backups available:
I've look through other log files, but cant find anything helpful.
Can anyone advice me how to fix it?
(CID:105466035)
Posted: 2020-07-03 12:00 AM . Last Modified: 2024-04-09 01:02 AM
Issue was resolved.
There were some problems with user permissions. I dont know what exactly it was.
I've uncheck "full control" permission for backup account and tick it again. Windows apply new permissions and voila! )
(CID:105466612)
Hello Valentin, Is there anything else in the swshare directory other then DCE backups? I have seen issues with directories that contain other files/folders that are not DCE backups cause the issues you are seeing. The second recommendation would be to restart the FTP server on you PC then try to restore the server again without trying a backup or a test mount. Thanks Victor
(CID:105466265)
Hi Valentin Kozlov, did you see this question from Victor? Best, Stine
(CID:105466586)
Thank you Victor, Stine! The folder contain only backup folders and files. Issue was resolved.
(CID:105466609)
Issue was resolved.
(CID:105466612)
HI Valentin Kozlov, glad to hear it was resolved. Thanks for sharing. Best, Stine
(CID:105466947)
Posted: 2020-07-03 12:00 AM . Last Modified: 2023-10-31 10:24 PM
