Posted: β2020-07-02 09:15 AM . Last Modified: β2024-04-10 01:17 AM
DCE VM will not accept network setting changes via desktop client. Is this intended?
(CID:93192606)
Hi Christopher,
Can you advise what network settings you wish to change? The public IP network settings or the network settings on the private network adapter? Is it just the IP address of DCE or all the networks settings?
You should be able to change network settings on the DCE client, although you will get a warning message about updating the Netbotz appliance post settings as the IP address you configured initially on the DCE is used to send alarm data to the DCE server using that IP address.
Breda
(CID:93192615)
(CID:93192648)
(CID:93192649)
Hi Christopher,
Thanks for the clarification. When it comes to changing the DNS settings via the DCE client, there is a bug logged on this. It is specific to the DCE VM. On the hardware version the issue is not present when changing the DNS settings.
For the moment the DNS settings for versions 7.2.1 and higher needs to be changing on the VM console. The username/password to this VM console is apcsetup/apcsetup.
B
(CID:93192713)
This has been fixed in DCE 7.2.6 which has just been completed and will be announced shortly.
(CID:93194025)
Posted: β2020-07-02 09:16 AM . Last Modified: β2024-04-10 01:16 AM
I was also having this problem and was able to change the DNS setting via the console but there is no option to change the Hostname or Domain from the console. Is there a manual way to change the Hostname or Domain, if not, do we have a rough release date for DCE 7.2.6?
I can change the Hostname from the client, but the Domain is still an issue.
(CID:93194078)
(CID:93913091)
Posted: β2020-07-02 09:16 AM . Last Modified: β2023-10-31 10:24 PM
