Posted: 2020-07-02 09:16 AM . Last Modified: 2024-04-10 01:16 AM
I have a double rail breaker panel where A-rail and B-rail have diffrent phase sequence(since this is supported in the physical breakers). How do i model this in the Breaker panel?
Currently there is no option that allow me to choose on what phase an individual breaker is connected to!
(CID:93192608)
The ordering L1, L2, L3, L1, L2, L3 and so on is fixed. You can however block out positions, so the bus bar starts from phase L2 or L3. Individual positions it the middle of a panel can also blocked.
You block a breaker position by opening the properties page of the PDU in the Genomes. Then under the Breaker Panel property page you can edit the circuit number of generic breaker panels by double clicking them. If you delete the circuit number that position will be blocked out. You can also change the circuit numbers of the positions. See the picture below.
Is there a specific order of phases you are interested in, or is it the ability to customize from breaker panel to breaker panel that is needed?
(CID:93192654)
(CID:93192654)
(CID:93192655)
(CID:93192661)
Posted: 2020-07-02 09:16 AM . Last Modified: 2023-10-31 10:22 PM
