Posted: 2020-07-02 09:17 AM . Last Modified: 2024-04-10 01:16 AM
I a m building a report in insight and i am struggling with a data binding to sum up the numbers from one column (rack_sqft), if in the 'Tags' column is equal to 'INSTALLED'
I am trying to build this in the eqpresion builder. Any help would be great.
Malc
(CID:93192715)
Hi Malcom,
I'm not 100% sure what it is you are trying to build in your report.
One way might be to try something like described here for another example:
https://jazz.net/forum/questions/38671/quotgroup-byquot-equivalent-for-birt
Otherwise if combining in a group is not what you want to achieve please elaborate a bit on your question.
(CID:93192761)
Posted: 2020-07-02 09:17 AM . Last Modified: 2023-10-31 11:34 PM
