Posted: β2020-07-05 04:01 PM . Last Modified: β2024-04-03 11:13 PM
Hi
We're trying to create a wall under the raised floor, as you can see at the picture below :
In this example we want to have a wall where the red X is located.
Is it actually possible?
(CID:137732025)
That's not supported - in general modeling equipment or wall under the raised floor is not supported/possible.
Kind regards
(CID:137732284)
Kind regards
(CID:137732284)
Posted: β2020-07-05 04:02 PM . Last Modified: β2023-10-22 01:07 AM
