How to add additional user DCO
  • How to add additional user DCO
129
72
Posted: ‎2020-07-05 04:00 PM . Last Modified: ‎2024-04-03 11:13 PM
1475
Is it possible to add additional users to Data Center Operations? Im not seeing any area to create users?
(CID:137731826)
  • Data Center Operation
Replies 10
Hello Lucas.
User management in DCO is in the DCO web client. To access, use a browser to browse to https://dco-server-ip-or-name/ and logon as a user with the user security permission.
The users option is under the administration menu of the web client. Please find more information here: Managing DCO users and user rights
Regards
Greg Sterling
(CID:137731835)
1476
Hi Lucas, to create new user use the StruxureWare Data Center Operation Web Client, http://sxwhelpcenter.ecostruxureit.com/display/public/UADCO8x/Managing+DCO+users+and+user+rights
(CID:137731837)
You are logged on as user apc? I assume yes if the server is fresh installed.
Which version of DCO did you install? Can I assume its 8.2.12?
You do not see this menu in the web client?
Regards
Greg Sterling
(CID:137731848)
Posted: ‎2020-07-05 04:01 PM . Last Modified: ‎2024-04-03 11:13 PM
Hey Greg i did install 8.2.12 and logged into the system as apc/apc initially however i think i might have locked myself out of the apc account is there a easy way to reset?
(CID:137731868)
The account should only remain locked for a short period of time (like 30 mins) ... it should unlock itself.
Regards
Greg Sterling
(CID:137732566)
I was referring to the password of apc account?
(CID:137732568)
Hello Lucas. I will direct email you the procedure.
Regards
Greg Sterling
(CID:137732602)
Hey Greg,
Upon logging into the web console im not seeing the option for users, how can i check my permissions ?
Just to note I just spun up a new DCO instance and my account is the only one created as far as im aware. I am able to login to webmin with the root account also.
(CID:137731842)
Greg has provided a reset procedure. This has fixed my issue.
(CID:137732614)
Posted: ‎2020-07-05 04:01 PM . Last Modified: ‎2023-10-22 02:25 AM
