Bus bar issues
  • EcoStruxure IT forum
  • Bus bar issues
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:02 PM . Last Modified: ‎2024-04-03 11:13 PM
613
Bus bar issues
Hello
We have created a data center In the DCO and realized that the bus bar is located on the floor when we get inside 3D vision (as you can see in picture number 2 below).
How can we locate them like in reality? In real, inside the data center, the bus bars are on the top..
Thanks!
(CID:137732031)
  • Data Center Operation
Currently floor mounted equipment can be modeled in DCO, so unfortunately it is not possible (not supported) to model equipment that may be wall-amounted and/or ceiling-mounded. I would have suggested your work around, namely to model them on the floor and perhaps could add a custom property saying about the device physical location (right click on the device/bus bar, Properties > Properties (Custom) and then add Name/Value).
Kind regards
(CID:137732295)
Kind regards
(CID:137732295)
Posted: ‎2020-07-05 04:02 PM . Last Modified: ‎2023-10-20 05:03 AM
