Connecting a PS100 Particle Sensor to a Netbotz 500 NBRK0570.
  • EcoStruxure IT forum
  • Connecting a PS100 Particle Sensor to a Netbotz 500 NBRK0570.
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:09 PM . Last Modified: ‎2024-04-09 01:13 AM
718
Good day,
Is it possible to Connecting a PS100 Particle Sensor to a Netbotz 500 NBRK0570.
(CID:105462359)
  • NetBotz
718
Hi IESLUSER,
It is possible to connect a PS100 Particle Sensor (NBES0201) to a Netbotz 570. You will need to use the Sensor pod 120 (NBPD0122) inconjuction with the Netbotz 570 to connect the Particle Sensor.
You can use this combatility matrix link I have listed below as reference.
http://www2.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/234000/FA234...
Kind Regards,
Andrew
(CID:105462361)
Replies 5
719
Hi IESLUSER,
Kind Regards,
Andrew
(CID:105462361)
The NBPD0122 is an older netbotz sensor pod which still can't connect to the NBRK0570 unit, this can't work.
(CID:108825736)
As stated in the Compatibility Matrix that I listed above, the NBPD0122 it is compatible with the Netbotz 570. The NBPD0122 connects via a USB Type A to B Cable to the Netbotz 570. Please also see the link to the installation manual for the Netbotz 570, which references how the Sensor Pod 120 is connected to the Netbotz 570 on Page 22 (Page 28 of the PDF). http://dcimsupport.apc.com/download/attachments/92078096/990-3291f-en.pdf?version=1&modificationDate...
(CID:108825737)
Thank you.
(CID:105467435)
Posted: ‎2020-07-02 11:09 PM . Last Modified: ‎2023-10-31 10:21 PM
