Tags are Removed when deleting demo licenses
  • EcoStruxure IT forum
  • Tags are Removed when deleting demo licenses
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:08 PM . Last Modified: ‎2024-04-09 01:13 AM
444
Hi All,
One of our customer was using Demo DCO Colo licenses.
I decided to user DCO Base Linceses.
We removed  DCO Colo  licenses from the  system and add DCO BASE licenses.
After that, Tags are dissappeared from the system.
Is there any method getting them back ?
Regards
(CID:105462355)
  • Data Center Operation
There should be a backup of the solution on the server from before you removed the license. As a first step try to secure the latest backup from before the tags disappeared.
I haven't heard of this issue before, so I don't know if there is a quick way to get the tags back without restoring an older backup.
Which version of DCO is the customer using?
(CID:105462357)
Posted: ‎2020-07-02 11:09 PM . Last Modified: ‎2024-04-09 01:13 AM
Hi Emre,
That make sense, because additional to the basic Operations license, Tags (and configuring tags) would require Capacity license. I don't think your Tags are disappeared from the system, but you need to install the required license, ie. the Capacity license.
Kind regards
(CID:105462431)
Posted: ‎2020-07-02 11:09 PM . Last Modified: ‎2023-10-31 11:38 PM
