PDU power consumption
  • EcoStruxure IT forum
  • PDU power consumption
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:27 PM . Last Modified: ‎2024-04-09 01:13 AM
747
Hi Team,
 I am not sure if my configuration is right or upgrade was failed but after last upgrade my PDU power monitoring does not working, my problem is that DCO PDU power monitoring does not synchronize with DCE power monitoring.
DCO: PDU 43-L1 shows 1,4 KW power consumption
but real date from DCE is 230 W
Communication DCO with DCE seems ok
MISSING IMAGE: imgv5.png
(CID:105462374)
  • Data Center Operation
Hi David,
Those numbers are not suppose to be the same and comparable - DCO collects the peak (and average) values over the last 30 days (default) and that value cannot be compared with the real time sensor value(s) from DCE.
Kind regards
(CID:105462433)
Hi David,
Kind regards
(CID:105462433)
Posted: ‎2020-07-02 11:27 PM . Last Modified: ‎2023-10-31 11:28 PM
