Posted: 2020-07-02 11:27 PM . Last Modified: 2024-04-09 01:13 AM
I need to change the address of the ntp server used by dco. we have our own internal server
(CID:105462390)
Brian,
NTP servers can be set using: Webmin > StruxureWare DC Operation > Setup > NTP Servers.
Best Regards,
Cory
(CID:105462399)
Posted: 2020-07-02 11:27 PM . Last Modified: 2024-04-09 01:12 AM
Hi Cory, I have a problem while sync ntp server with DCO server as you can see at attached. Did you see any error like that or do you know where is the problem? I integrated before that NTP server with DCE. Thanks Kerem
(CID:105464946)
Posted: 2020-07-02 11:27 PM . Last Modified: 2023-10-31 11:03 PM
