Posted: 2020-07-05 07:33 PM . Last Modified: 2024-04-03 02:37 AM
I just like ask SE experts to confirm my understanding of the supported backup/restore scenario in EcoStruxure IT Gateway.
I think supported scenarios are 1 and 2. Then number 3 is not supported. Am I correct?
As far as I experienced using Gateway 1.6.0.39(Win), the following things are needed to be known for restoring. I think this also worth for sharing.
If there is something incorrect or missing, please comment.
Akihiro Yamagami
(CID:143760601)
Hello Akihiro,
i will raise a ticket for you on support@ecostruxureit.com to get you a proper answer.
Please hold
(CID:143760677)
Thank you for your collaboration with support team and giving quick answer.
I understand well.
P.S.
If there is the topic which explain the supported backup/restore scenario in the FAQ or somewhere on HELP CENTER, I think it will be also helpful for the other users.
(CID:144310910)
Jackie Lehr
(CID:144310980)
Posted: 2020-07-05 07:33 PM . Last Modified: 2023-10-20 05:08 AM
