Posted: 2020-07-02 09:39 PM . Last Modified: 2024-04-09 01:43 AM
We have all the onsite techs authorized via a RADIUS server, that works fine. We have some racks that only need certain people to have access too. I intended on adding them as local registered users. There is a option for RADIUS, then Local authentication. If you make it local only .. the registered users work, but if you choose RADIUS server, then local for authentication, the local users no longer have access.
probably something simple I missed
Thanks in advance
(CID:105459057)
Posted: 2020-07-02 09:40 PM . Last Modified: 2024-04-09 01:43 AM
Aric,
The Radius server will always be used for authentication until the connection to it is lost. Once the connection is lost, local authentication is used.
Best Regards,
Cory
(CID:105459059)
Aric,
Best Regards,
Cory
(CID:105459059)
Posted: 2020-07-02 09:40 PM . Last Modified: 2024-04-09 01:42 AM
Gotcha so if your using a RADIUS server you cannot use the local .. I thought it would use both, radius .. then if it didnt find anything it would check local.
Thanks for the clarification.
(CID:105459709)
Posted: 2020-07-02 09:40 PM . Last Modified: 2023-10-31 10:18 PM
