Posted: 2020-07-02 09:39 PM . Last Modified: 2024-04-09 01:43 AM
Hi All,
I have tried to integrade with HP oneview but I couldnt set up the external connection. I have the right credentials(I have tried with admin and read-only rights) on HP OneView and I know that there is no network issues. Can you please give more details about this integration? Do I need any ports to be opened? What kind of administrative rights do i need?
Thanks in advance
(CID:105459054)
Kaan Are you using a recent version of HP OneView? i.e. version 1.2_04 or newer? If yes, you need to add the SP3 service pack to DCO 7.5. A patch was added to that service pack which fixes a connection problem between DCO and OneView. The connection problem prevents the external systems tool from establishing the OneView connection. Regards Greg Sterling
(CID:105459233)
(CID:105459233)
Thanks Greg, we have resolved the problem after installing the service pack.
(CID:105459235)
Kaan Kutlug Would you be able to share any screen shots of the daa you recieved back from OneView? Do you get back CPU utilisation and power stats for each server - as if you had connected to it via a server discovery in ITO?
(CID:105465523)
I have attached a word doc for your review. It contains a quick summary of the OneView features and how they are tied back to the DCO licenses and a few screenshots of the data you'd see.
(CID:105465572)
Greg Sterling thanks for the documents - very helpful.
(CID:105465631)
Posted: 2020-07-02 09:39 PM . Last Modified: 2023-10-31 11:07 PM
