Network Management Browser Issue
  • Network Management Browser Issue
129
72
Posted: ‎2020-07-02 09:38 PM . Last Modified: ‎2024-04-09 01:43 AM
726
We have a customer who has reported a problem with Network Mangement browser in DCO 7.5 retaining connections after a device is deleted:
So,
1 - A network route is created between Server and Network Switch
(Server 1) > (Patch Panel 1) > (Patch Panel 2) > (Network Switchport)
The two Patch Panels have back to back connections.
Server 1 and Network Switchport are connected to the front of the patch panel.
2 - Server 1 is deleted from DCO
However, the network management browser retains the Server 1 to Patch Panel 1 connection after the deletion. This entry remains in the browser even after several hours have passed.
Are there any known issues with this / could this be checked out?
Many Thanks
(CID:105458889)
  • Data Center Operation
726
Hi David,
I've just checked this out, as far as I know, we have not registered a similar issue before, so it doesn't seem to be a known issue. As illustrated, based on your nicely described steps, I'm not able to reproduce the reported issue. By removing my server1, the cable connection is cleared as well.
We might need more info or logs if possible, thanks.
Kind regards
(CID:105458892)
Hi David Is the cable there even after a client restart? Would it be possible to get the application.log file from the client application - it might contain information about an error that prevented the network management browser from refreshing? Regards, Ulrik
(CID:105458930)
Posted: ‎2020-07-02 09:38 PM . Last Modified: ‎2023-10-31 11:27 PM
