Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2024-05-17 06:34 AM . Last Modified: 2024-05-17 06:38 AM
Hi All,
Is there a way we can use our NetBotz to measure room air pressure, particle count (per cubic meter), temperature below -5 degrees Celsius and air velocity as precise as m/s. I'm aware the Room Sensor Pod can measure airflow but to a measure of m/min and this cannot be changed.
Perhaps any 3rd Party Sensors that are compatible to measure the above?
Thank you!
Posted: 2024-05-20 04:32 AM
Hi @Tafadzwa,
There are multiple types of 4-20 mA sensor configurations that may suit what you need, but you will need to see if there are any sensors on the market that match your required criteria. Here are some screen captures from the NetBotz 750 so you can see the multiple options for 4-20 mA sensors (limit 2 per appliance as they are 4-20 mA ports that are built into the appliance):
For something like particle count, you could use one of the 4-20 mA sensor connections as well and just choose the sensor type of 4-20mA, the requirement would be finding a third party sensor that meets your requirements:
You may also be able to use a 0-5V sensor, but I unfortunately do not have one on hand to provide you with screenshots of that configuration.
Kind Regards,
Cory
Hi @Tafadzwa,
Kind Regards,
Cory
Posted: 2024-05-20 07:38 AM
Thank you for your feedback.
Do you perhaps have any recommendations for 3rd Party sensors I can have a look at?
Posted: 2024-05-22 12:08 PM
Hopefully other community members with experience in different 3rd party sensor options can help out here.
Cory
