Posted: β2020-07-02 12:43 PM . Last Modified: β2024-04-09 11:44 PM
Asking on behalf of Brian Flynn.
Can DCO import Vision drawings ?
(CID:96764762)
HiBrian Flynn
it is not possible to import Visio drawings into DCO.
It is currently supported to import CAD drawings. More details regarding CAD import can be found CAD Import Supported Entities
(CID:96764776)
Maybe convert the Visio to .png and add it as a background image ..?
(CID:96764790)
It is possible to convert Microsoft Office Visio 2003 drawings directly to AutoCAD Drawing (*.dwg). Here is how:
https://support.microsoft.com/en-us/kb/888700
(CID:96764856)
I have used the method that Stanislav Kalianov refers to successfully a number of times. The only thing you need to do is to load the file into AutoCad and add the correct unit of measure - as this is not done in the Microsoft DWG export.
(CID:96764883)
Posted: β2020-07-02 12:43 PM . Last Modified: β2023-10-31 10:18 PM
