Posted: 2020-07-03 05:31 PM . Last Modified: 2024-04-08 12:10 AM
我在NetBotz看到它支持的驱动程序,有一个中型MF100型号,那么这个设备是不是附加到设备上?这可以用来发短信吗?
(CID:122095389)
Can you please clarify what your question is. Are you asking if that modem is supported with NetBotz?
If that is your question, then the list of supported modems is available on the FAQ below.
http://www.apc.com/us/en/faqs/FA158359/
Regards
(CID:122095497)
您好,附件是MF100,这是与FAQ中提到的MF100相同的设备。那么这个设备怎么使用?我看了这个设备的说明,它是一个网卡。我可以用它发短信吗?
(CID:122095507)
Posted: 2020-07-03 05:32 PM . Last Modified: 2024-04-08 12:10 AM
You can use it to send SMS or text message. Plug in this modem into the USB port of Netbotz appliance. After that you can choose ZTE MF100 from the serial interface drop down list, if the modem is recognized by Netbotz, a SMS icon will appear under Configuration page.
Thanks.
(CID:122095694)
It turned out you have to set up SMS notifications. Can Photo settings?
(CID:123345308)
Posted: 2020-07-03 05:32 PM . Last Modified: 2023-10-20 04:58 AM
