Adding customer via DCO REST web service api
  • Adding customer via DCO REST web service api
129
72
Posted: ‎2020-07-03 05:32 PM . Last Modified: ‎2024-04-08 12:10 AM
1268
DCO 8.x supports using the Customer REST web service, when/if needed we can use this web service to add a customer. Here is a simple how to do:
https:///api/current/docs/index.html
(will be prompted to login)
and then go to "customers -> POST", enter the customer/'company' details, and then execute it by pushing the "Try it out" button:
Activating the customer can be done via web-client - as illustrated, go to Administration > Customers > ACTIVATE CUSTOMER, then select the customer that needs to be activated...
Kind regards
(CID:122095799)
  • Data Center Operation
Replies 6
Hi Jef,
How many company types string can I use? I tried INTERNAL_COMPANY, but failed.
(CID:124527258)
Hi Brenda,
It works fine for me, even using a 50+ character company name.
If it is not working for you, then please post a question (in Community) with details and screen captures illustrating the issue, then I will take a look, thanks.
Kind regards
(CID:124527390)
Hi Jef,
I found out the reason, there are only two company type , EXTERNAL_COMPANY and INTERNAL_DEPARTMENT.
BR
(CID:124527412)
Really useful Jef Faridi!
One thing to note is how the mapping is done between the fields:
"Department" will turn into the "Account No." field, not entirely intuitive.
(CID:132649888)
Many thanks Christian,
I do agree with you that for a better user experience, it would be great to use the same word(s). I have registered a possible enhancement case for this, thanks.
Kind regards
(CID:132650793)
Posted: ‎2020-07-03 05:33 PM . Last Modified: ‎2023-10-20 04:59 AM
