Posted: β2020-07-05 05:58 PM . Last Modified: β2024-04-03 03:10 AM
I have two ATS APC AP4424 Models which appear normally on DCE (all sensors work normally) but I get an error "Device Definition File (DDF) Transfer Failure " I have checked the Device File Transfer Settings' lists the Username, Password and IP Range combination needed to access this device and I have verified that the ftp service runs on the ATS devices (I am able to connect with a ftp client to the device)
(CID:140713749)
Dear Interworks.Cloud,
Tell us, please, did you solve your problem or not?
With respect.
(CID:141269201)
yes it worked with the firmware upgrade
(CID:143754906)
Ok, very thanks for the good feedback π.
(CID:143754910)
Posted: β2020-07-05 05:58 PM . Last Modified: β2023-10-20 04:56 AM
