Posted: 2020-07-03 03:24 PM . Last Modified: 2024-04-08 12:59 AM
Hi Guys,
I am trying to setup SSHv2 only preferably but wanting to maintain access via Terminal, Command Line or Putty. Though enabling these on either devices continually fails with SSH issues, none of which allow a SSH connection.
Unable to negotiate with 10.x5x.2xx.x4x port 22: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1 with V1 and v2 enabled, encryption v1 Blowfish 128bit, v2 Blowfish 128Bit, AES 128bit, AES 256bit.
Practically, all fail no matter what! What has anyone else been able to get to work, that meets good security practices, as I am not keen to enable already exposed security exploits.
Thanks in advance
(CID:116923164)
Hi Matthew Wren,
What is the firmware version on your device? The actual is:
Application Module
Version: v3.9.2
Date: 03/22/2016
Time: 20:13:25
APC OS (AOS)
Version: v3.9.2
Date: 07/06/2016
Time: 15:12:05
With best regards.
(CID:116923195)
Hi Matthew Wren,
Did you find an answer to your question? 😀 If not I will recommend that you contact your local tech support, you can find the information here: http://www.apc.com/us/en/support/contact-us/index.jsp
Kind Regards
Ditte
(CID:119050911)
Posted: 2020-07-03 03:24 PM . Last Modified: 2023-10-20 04:55 AM
