Posted: β2020-07-05 07:47 PM . Last Modified: β2024-04-03 02:32 AM
Hello, just imported a few netbotz to struxureware that had been installed a long time ago. They were version 4.4.0. I did an upgrade to 4.6.4 and the camera version showed 4.6.3. The camera showed, but it was a test screen and not connected. I flashed to 4.6.2 per another support comment posted before and it shows no camera or test screen and also camera not connected. I upgraded to 4.6.4 and still shows no camera connected. Do I need to turn it on somehow?
(CID:144313523)
I talked with tech support and flashed the 355 several times and camera still didn't show. Determined the unit to be faulty.
(CID:144313976)
Posted: β2020-07-05 07:47 PM . Last Modified: β2023-10-20 04:53 AM
