Gateway cannot read the configuration file from the device
EcoStruxure IT Expert Troubleshooting
How to troubleshoot and solve issues configuring and using EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • EcoStruxure IT Expert Troubleshooting
  • Gateway cannot read the configuration file from the device
  • Mark as Read
  • Asset Definition service for DCE DDFs and Gateway ...
  • Why does my UPS Score assessment show my battery i...
  • Symmetra UPS battery wear information in UPS asses...
  • Location hierarchy doesn't match DCE device groups
  • I can't find my devices on the network
  • I am getting unauthorized FTP access emails daily
  • How can I delete my EcoStruxure IT account?
  • Gateway cannot read the configuration file from th...
  • Galaxy UPS battery wear information in UPS assessm...
  • Devices are offline in ITE
  • Alarms do not update in EcoStruxure IT
  • Access denied error: Login initiated from a bookma...
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT Expert Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2023-02-17 06:17 AM
Configuration for a device can be unavailable in IT Expert if the device is misconfigured.
Note: Only APC NMC devices are supported.
To troubleshoot:
  • Device credentials are not configured correctly
    Make sure the SCP and FTP settings are configured correctly on the APC NMC device and in the Gateway.
    Configure Gateway device file transfer settings
  • Device config.ini contains line breaks
    IT Expert cannot process the config.ini file for APC NMC devices if any entry in the file contains multiple lines.
    Line breaks can be introduced into the config.ini file [SystemID]Message field when multiple lines are used in the System Message on the NMC's Configuration > General > Identification page.
    1. Log in to the NMC.
    2. Remove or replace the System Message.
      If a System Message is needed, make sure to type the message in one continuous line with no line breaks.
    3. Reboot the NMC.
    4. Rediscover the device in the Gateway.
