Posted: 2025-05-16 04:12 AM
Is there a tool for working with log files?
Log files are quite large and complex, so maybe there is a tool for working with them where I could use filters.
Posted: 2025-05-18 03:32 PM
Depends on the log files.
For DB logs and some driver logs, https://community.se.com/t5/Geo-SCADA-Knowledge-Base/CS-File-Analyser/ba-p/278766 however it hasn't been updated in a very long time which is a major shame as the tool was very powerful once you got used to the features (the person who originally wrote it left Schneider about 8 years ago and various people have tried to pick it up since)
For comms/IO logs you have https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Driver-Log-Translator-Picker-Utility/ba-p/27897... which is really a wrapper to running driverwhatever.exe /translate from the command line (if the tool doesn't work properly can just do the translate manually)
For ViewX logs, not aware of any tool.
Posted: 2025-05-21 06:25 PM
File analyser still works, you just have to remove lines that it can't parse because they've changed since it was published; from memory ICMP.
If you're using the latest SCADA version, you don't need the picker any more, you can translate directly from server status/modules.
