Posted: 2025-05-11 03:16 PM
My client has a group of tags llisted under "~ mimics" as a group name. I cannot read them with my OPC DA client and suspect that the tilde character is being rejected as a special character. Does the tilde character mean anything in geoSCADA, or is this just a random choice that is disrupting my ability to read data?
Posted: 2025-05-11 09:30 PM
It’s just a convenient choice of non-alphabet that doesn’t have special meaning elsewhere.
In SQL _ and % are used for wildcards, ? Is used for query placeholder
‘ and “ are used as string delimiters in different languages, so would be confusing
. is the FullName separator…
so not many options left, ~ was used in some early Serck stuff, and kind of just multiplied from there.
I’d try to follow up either your OPC-DA client vendor, it shouldn’t really have any issue with that character.
changing names of things in unknown DBs is a recipe for disaster… especially ~ things, they’re normally special enough to want to be sorted graphically to the top
Posted: 2025-05-12 08:34 PM . Last Modified: 2025-05-12 08:34 PM
~ became defacto for "common things" especially when made consistent between multiple systems such as "~Config", as Bevan mentioned all it really does is move them up the Geo SCADA tree alphabetically so it is much easier to find (although in some third party clients ~ comes after Z, maybe that is causing the issue here?)
! has also been used, comes after the ~ but before A and only ever really seen it for system monitoring type groups
Posted: 2025-05-21 06:18 PM
Could also be security stopping you from reading those groups, they tend to require admin.
