Posted: 2019-11-06 06:31 AM . Last Modified: 2023-05-03 12:28 AM
>>Message imported from previous forum - Category:ClearSCADA Software<<
User: nminchin, originally posted: 2019-01-15 06:14:26 Id:348
Hi, I'm trying to configure a connection to ClearSCADA via ASP.NET to execute a query to display info on a local intranet webpage, but I can't get the connection string formed correctly. I'm not sure that I'm using the right provider name?
Currently I have:
in Web.Config:
```html
in TestODBC.aspx:
```ASP
body { background-color: IndianRed; }
South Australia - All Site Logs (View only)
The error I get is:
`[ArgumentException: Unable to find the requested .NET Framework Data Provider. It may not be installed.]`
I'm not really sure where to go to from here... any help is very welcome!
Nick
Posted: 2019-11-06 06:32 AM
>>Responses imported from previous forum
Reply From User: nminchin, posted: 2019-01-15 06:35:00
Worked it out.
The providerName should be System.Data.ODBC.
E.g.
Also there was an error in the aspx file:
` DataSourceID="SqlDataSource1" Font-Size="Smaller" ForeColor="#333333" DataKeyNames="EntryNumber" EnableModelValidation="True"`
should be:
` DataSourceID="SqlDataSource1" Font-Size="Smaller" ForeColor="#333333" DataKeyNames="FullName" EnableModelValidation="True"`
Also, I changed the connection string away from using a DSN as I don't like relying on DSNs to be created:
`connectionString="DRIVER=ClearSCADA Driver;SERVER=Net"`
Worked it out.
E.g.
should be:
