Posted: 2024-01-30 04:12 AM
Posted: 2024-02-01 02:49 AM
Code in C# to do this:
ClearScada.Client.Simple.Connection SimpleConnection;
ClearScada.Client.ServerNode node = new ClearScada.Client.ServerNode("127.0.0.1", 5481);
SimpleConnection = new ClearScada.Client.Simple.Connection("Utility");
SimpleConnection.Connect(node);
var secure = new SecureString();
// *** Modify to set your password and user name
var user = "";
var pass = "";
foreach (var c in pass)
secure.AppendChar(c);
SimpleConnection.LogOn(user, secure);
var userObject = SimpleConnection.GetObject("Demo Items.GEO Demo.Mobile.Darren");
var userGroupIds = userObject.GetProperty("UserGroupIds");
// You could read the old Ids and append, for example
var newGroup = SimpleConnection.GetObject("Demo Items.ExtAuth.LDAP.Groups.External WWW");
object [] gids = { newGroup.Id };
userObject.SetProperty("UserGroupIds", gids);
Or in Python with Pythonnet (I'm using Python 3.12)
# Import .Net runtime support - needs "pip install pythonnet" Works on Python 3.8 & 3.12
import clr
# Get Geo SCADA Library (could use the namespace if the dll is on PATH)
CS = clr.AddReference( "c:\\Program Files\\Schneider Electric\\ClearSCADA\\ClearSCADA.Client.dll" )
import ClearScada.Client as CSClient
# Create node and connect, then log in. (Could read net parameters from SYSTEMS.XML)
node = CSClient.ServerNode( CSClient.ConnectionType.Standard, "127.0.0.1", 5481 )
connection = CSClient.Simple.Connection( "Utility" )
u = ""
p = ""
connection.Connect( node )
connection.LogOn( u, p )
userObject = connection.GetObject("Demo Items.GEO Demo.Mobile.Darren" )
from System import Object, Array, Byte
for i in userGroupIds:
gid = CSClient.ObjectId( i)
g = connection.GetObject( gid)
print(i, g.FullName)
newGroup = connection.GetObject("Demo Items.ExtAuth.LDAP.Groups.Test1")
newGroupIds = Array.CreateInstance( Object, 1)
newGroupIds.SetValue(newGroup.Id, 0)
userObject.SetProperty( "UserGroupIds", newGroupIds )
Posted: 2024-01-30 08:49 AM
Probably the same way as the Bulk Edit tool.
It's worth a try.
The Bulk Edit Tool sets it by the user Group's Full Name
Setting Multiple in it is entered with comma's and no spaces.
Like this Security.User Groups.My Group1,Security.User Groups.My Group2
Posted: 2024-01-31 09:42 PM
It turns out that it is not possible to set array of reference fields from a DML SQL query. It can only be achieved through code. I have now written a Powershell script to do the job. Once I've polished it I will probably publish it here for the benefit of others with a similar task. I've got the job done but it is functional but not yet suitable for publishing.
var user = "";
var pass = "";
import clr
u = ""
p = ""
