How to make a setpoint in Geo SCADA expert?
Select a Country
  • Remote Operations
  • How to make a setpoint in Geo SCADA expert?
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Aaron.Meng
Aaron.Meng
Contributor
Posted: ‎2023-01-04 05:02 PM . Last Modified: ‎2023-05-02 11:49 PM
2161
I want to make a setpoint in Geo SCADA expert to change the setting of PLC. Does anyone know how to configure it?
  • SCADA
  • Geo SCADA
Aaron.Meng
Aaron.Meng
Contributor
Posted: ‎2023-01-05 08:42 PM
In response to AndrewScott
2131
I found it. The Promote under the Control tab need to be enabled. Thanks
Replies 4
AndrewScott
AndrewScott
Leader
Posted: ‎2023-01-05 01:59 AM
2147
You've not specified which driver (Modbus, DNP3, IEC 60870-5 etc.) you're using. In general, create an output point (e.g. DNP3 Binary Output), however for drivers that don't have separate input & output points just enable controls on the point.
Andrew Scott, R&D Principal Technologist, AVEVA
Aaron.Meng
Aaron.Meng
Contributor
Posted: ‎2023-01-05 07:00 PM
Hi Andrew, thanks for your reply. Currently I use Modbus, I can read the value of the register ( e.g. 40001), but I can't change the value of it.
  • Geo SCADA
Aaron.Meng
Aaron.Meng
Contributor
2132
AndrewScott
AndrewScott
Leader
Posted: ‎2023-01-06 01:34 AM
In response to Aaron.Meng
I think you're mistaken. The Promote feature allows you to automatically promote scanning (to a faster rate) on selected outstation(s) when you control a point, to get feedback from the consequences of the control more quickly.
To write to a Modbus holding register you need to configure either a Modbus Generic Analog Output Point or Modbus Generic Digital Output Point and then use the Control method to perform the write.
