Geo SCADA v6.81
  • Remote Operations
  • Geo SCADA v6.81
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2021-10-18 10:24 AM . Last Modified: ‎2023-05-03 12:01 AM
1
1015
Geo SCADA v6.81
I hope you're well.
What is the underlying Database technology used GeoSCADA v6.81.  Is it Schneiders own technology,  an open source database or can customer choose their own database technology from their favourite vendor?
I've working with a client to find a way to export the GeoSCADA v6.81 schema/meta-date into a data governance tool.
regards
James Taulbut
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: ‎2021-10-18 02:59 PM . Last Modified: ‎2022-10-19 01:21 AM
Hi James,
It is a proprietary but with open interfaces, see https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Supported-Interface-and-Protocol-Versions/ba-p/... for some details as well as the product help.
For what you're trying to do, my guess is you'll want to parse the schema which by default is at https://localhost/schema on the server (it is simple XML but dynamically generated based on what modules you install and what your configuration/metadata is) which will provide you the database structure, and then for the data part you have lots of options depending on what type of data you actually need (configuration, events, historic, etc) and if real-time or batch/reactive.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
