  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Call built-in Interval Control as a user Pick Action
  • Communities
  • Remote Operations
  • Re: Call built-in Interval Control as a user Pick Action
  • Subscribe to RSS Feed
sbeadle
Janeway sbeadle Janeway
217
BevanWeiss
Spock BevanWeiss
81
AndrewScott
Captain AndrewScott
54
AdamWoodland
Commander AdamWoodland Commander
23
rlao
Lieutenant rlao
Lieutenant
Posted: ‎2020-01-14 10:20 PM . Last Modified: ‎2023-05-03 12:19 AM
1672
When configuring fields such as alarm redirection delays and execution offsets (time-based interval properties) in a database object's properties, it brings up a nice Interval control popup that lets you explicitly specify number of hours, minutes, seconds, etc. which makes configuration very intuitive.
However, when you call a control method on those types of properties as a pick action for example, you don't get that nice interval control popup. You just get a generic control dialog box and you are forced to input your desired interval as number of seconds.
Is there a way to call that nice Interval control as a user method so I can put it into a mimic script?
  • SCADA
  • Telemetry
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-01-15 10:47 PM
1656
There is no way that I know of to do this.
In the past we've always had to create a VB form to allow for such 'complex' data entry.
It might warrant a feature request however.  I'm just not sure how it could be exposed.  The ?Control action really attaches to an entire point object.  I guess there could possibly be a ?Configure:'PropertyName' action exposed which would call up the appropriate custom dialog for the PropertyName specified.  Aggregates could be handled with
?Configure:'AggregateName.PropertyName'
But again, I don't believe anything like this is currently available within ClearSCADA.
Replies 4
BevanWeiss
Spock BevanWeiss
Spock
1657
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-01-15 11:01 PM
In response to BevanWeiss
1654
Immediately after I posted the reply I thought of a way that 'might' have worked.  But I just tested it and it didn't.  So you can strike out this option.
If you call a Logic Program which has VAR_INPUT parameters configured, put don't specify them when executing (through a UI control), it will prompt you to enter the parameter value.  I was hoping that having a TIME VAR_INPUT it would prompt in a fashion that allowed for entering of time duration, which could then be scaled into the appropriate property value.  Unfortunately this was not the case, and it only provided a simple text entry field (which I'll raise a feature request to try to enhance).
So there's no working option I can recommend sorry.
tfranklin
Lt. Commander tfranklin
Posted: ‎2020-01-16 05:53 AM
We've requested this feature a number if times in the past.  My first thought was to have them utilize the DisplayObjectMenu function call and add an option for something like &ControlOnly=TRUE to the end.  DisplayObjectMenu accesses the entirety of the object similar to the ?Control function would.
We've tried using DisplayObjectMenu and excluding everything but control, but since there are other items in that "Group" of exclusions it ultimately still prompts you to select something prior to getting the control menu.
To those who roam the forums about, please consider this feature in future releases.  As Bevan mentioned, the only suitable workaround is to script a form that is somewhat complex due to consideration of varying datatypes and error handling with control min/max.
  • control
  • forms
  • pick action
rlao
Lieutenant rlao
Lieutenant
Posted: ‎2020-01-16 03:15 PM
Thanks bevan, I feared this might have been the case. Looks like I'll just have to script a user form myself
Additional options
Already have an account?Login
