DataType Enumerations
  • Remote Operations
  • DataType Enumerations
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
tfranklin
Commander tfranklin
Commander
Posted: ‎2020-01-14 03:53 PM . Last Modified: ‎2023-05-03 12:19 AM
2231
Where can one find the enumerations for the DataType OPC property?  I feel like this used to be on the resource center or in the Schema, but it's nowhere to be found anymore.  I ran a query to get what I needed but was curious where else we can look to find all enumerated values.
  • SCADA
  • DataType
  • Enumerations
  • opc
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: ‎2020-01-14 04:43 PM . Last Modified: ‎2020-01-14 04:50 PM
2228
Interestingly enough it is in the resource centre, just the draft content (since 2009!) so not public 🙂
Copy and paste as below, may well be outdated though (especially given Proteus, BMS and TMX are no longer core drivers):
The DataType property, found in the CDBPoint table, details the automation VARTYPE of the point's value.
DataType Value VARTYPE Name Point Type(s)
3VT_I4Integer (SNMP), Meter Period (BMS)
4VT_R4Analogue, Counter, Minimum, Maximum, Mean, Rate of Change, etc.
5VT_R8Analogue, Counter
7VT_DATEDate/Time
8VT_BSTRString
17VT_UI1Digital, Demand Buffer (Proteus)
19VT_UI4Cardinal (SNMP), Runtime (Proteus/BMS/TMX)
The property is read-only, so you cannot change the point type by changing it.
A common misconception is that this allows queries, logic and other parts of ClearSCADAto determine a point type easily rather than using TypeName or TypeDesc with a list of possible classes of each type, however this will rarely work as several types of point share each data type.
AdamWoodland
2229
7VT_DATEDate/Time
8VT_BSTRString
tfranklin
Commander tfranklin
Commander
Posted: ‎2020-01-16 05:57 AM
In response to AdamWoodland
Awesome, thank you!   This should make for some more efficient processes, rather than comparing string values of TypeNames.
I could've sworn these were previously enumerated somewhere.  Either way -- thanks again!
