OPC ParentGroupName property empty after update 2017R3
  • Remote Operations
  • OPC ParentGroupName property empty after update 2017R3
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
98
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Kees
Crewman Kees
Crewman
Posted: ‎2020-01-09 09:49 AM . Last Modified: ‎2023-05-03 12:19 AM
2849
After update to 2017R3 “November 2019 update” (6.80.7285.2) the OPC "ParentGroupName" property is empty.
We are using this property in application scripts. After update these scripts fail.
Anyone familiar with this problem?
  • Telemetry
  • ViewX
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2020-01-09 09:53 AM
2842
This issue has just been fixed earlier today and the fix will be included in the January 2020 monthly updates.
Andrew Scott, R&D Principal Technologist, AVEVA
Replies 5
AndrewScott
Admiral AndrewScott
Admiral
2843
Kees
Crewman Kees
Crewman
Posted: ‎2020-01-10 12:59 AM
In response to AndrewScott
2827
OK, thanks Andrew for your quick response.
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2020-01-10 01:46 AM
In response to Kees
2823
A potential workaround is to use the two dots on a relative reference to refer to a parent item.
e.g. "..FullName" is equivalent to ".ParentGroupName"
Kees
Crewman Kees
Crewman
Posted: ‎2020-01-10 03:24 AM
In response to sbeadle
2816
Hello Stephen,
Thanks for thinking along with us.
We use the field “ParentGroupName” in global scripts with query’s something like
sSQL = "SELECT FullName FROM CMimic WHERE ParentGroupName = '" & GroepFN & "' AND UPPER(Name) LIKE......
It’s a lot of work for us to change that and use the relative reference,
We will wait for the monthly update.
Kind regards, Kees
Kees
Crewman Kees
Crewman
Posted: ‎2020-01-14 11:52 PM
In response to Kees
For scripts you can use the PARENTGROUPID:
  • A.PARENTGROUPNAME.... => A.PARENTGROUPID->FULLNAME....
