PM8000 Device Support
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • PM8000 Device Support
Thierry_Baudard
Commander Thierry_Baudard Commander
8
EduardoFainblum
Commander EduardoFainblum Commander
6
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
Back to EcoStruxure Energy Hub
DeanZouganelis
Ensign DeanZouganelis Ensign
Ensign
Posted: ‎2023-06-08 05:03 PM
1304
Hi team,
I have seen that to connect PM8000 meters to EEH it is recommended to connect through a site server gateway. I also saw that while not recommended it can be done through a PAS600/800 with limited support and data available. Has anyone tried to connect a PM8000 to PAS? If so, what data was available?
For the application that this is for, the end user only wants to see Energy consumption at 3 different sites through EEH and they already have a PM8000 installed at each site.
  • Knowledge Base
Calvin_HopWo
Lt. Commander Calvin_HopWo Lt. Commander
Lt. Commander
Posted: ‎2023-06-13 09:36 AM
Hello Dean,
Was it the "Architecture Design & Selection" Document that this recommendation came from?
The PM8000 can be connected to EEH through a Panel server Gateway and this has been tested.  In terms of measurements, there should be little to no difference between the measurements that you get from a Panel server vs a Site Server.
The main difference is that the Site Server and Panel server have different capabilities so depending on what EEH modules or what you want to use EEH for might influence which Gateway you should connect through.  In general the Site Server offers more functionality for a higher end meter which is why it was probably recommended.
Some examples of the differences:
SiteServer
  • Can handle Near Real time requests from EEH for displaying values.
  • Onboard Meter Alarms/Events are passed up through SiteServer to EEH to be displayed/alerted on.
Panel Server
  • Currently cannot handle real time requests.  EEH will instead show the last known data record for those graphs/widgets.  (As long as the data point is less than 2 hours old.)
  • Currently only the Panel Server CommLoss alarm for the PM8000 Device is sent up to Energy Hub.  No onboard events/alarms are sent to EEH.
So if the customer wanted to get the Electrical Distribution Monitoring and Alarming (EDMA) or Energy Code Compliance module, then I would recommend a Site Server, otherwise you would be losing a lot if not all of the functionality of those modules if you connected through a Panel Server.
However, if it is only Energy Consumption that the customer is interested in then a Panel server should be fine.
Calvin_HopWo
Lt. Commander
Hello Dean,
SiteServer
Panel Server
