Energy Hub Virtual meter
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • Energy Hub Virtual meter
Thierry_Baudard
Commander Thierry_Baudard Commander
8
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
EduardoFainblum
Commander EduardoFainblum Commander
5
Marcus_Gasper
Commander Marcus_Gasper Commander
4
Back to EcoStruxure Energy Hub
Konstantinos_Patsaris
Crewman Konstantinos_Patsaris
Crewman
Posted: ‎2025-10-02 12:01 AM
171
Greetings Everyone.
We have Set up a Site in Energy Hub with 4 Power Tags all monitoring consumed energy.
We are trying to create a Virtual meter to show the total Energy Consumption of the Site.
To my understanding, in Energy Hub, the Virtual Meter can only show the difference between Consumed and Generated Energy. Also, we don't monitor main( incoming) energy, all the devices monitor feeder( outgoing) energy.
Is there a way to create a Virtual meter that shows the sum of the outgoing energy ?
Thanks in advance!
  • Knowledge Base
  • Tips and Tricks
  • Energy Hub
Thierry_Baudard
Commander
Posted: ‎2025-10-03 12:45 AM
Hi @Konstantinos_Patsaris
The virtual meter (VM) is calculated using the formula: Mains (incoming) minus Feeders(outgoing).
If you label all meters as "Mains (incoming)" and any meter as "Feeders(outgoing)," the VM will be equal to the sum of the "Mains (incoming)" meters as you expect.
meters.=> Screenshot 1 below for detail.
You can also perform a similar operation without creating a VM and using only EEH's native functionality.
If, in the SETUP>Energy view, all four PowerTags are configured to be in the same location (screenshot2).
Then in future investigation,  energy consumption of that location will be automatically equal to the sum of the energy measured by the four PowerTags/meters. (Screenshot 3 with an example)
Screenshot 1
Screenshot 2
Screenshot 3
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Thierry_Baudard
Commander
Screenshot 1
Screenshot 2
Screenshot 3
Thierry BAUDARD
