Math functions on ITE dashboards
Dashboard
How to design your own dashboard in IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • Dashboard
  • Math functions on ITE dashboards
  • Mark as Read
  • Video clips in IT Expert
  • Video: How to view the Audit Log in IT Expert
  • Alarms in the floor view in ITE dashboards
  • Resize and rearrange widgets on the dashboard
  • Design your own dashboard in IT Expert
EcoStruxure IT Support
Request Support
Back to Dashboard
  • Mark as Read
Picard EcoStruxureIT
‎2019-08-07 12:56 AM
Last Updated: Sisko JLehr Sisko ‎2025-11-20 10:31 AM
When you add a graph widget or single value widget to an ITE dashboard, you can use math functions to add calculations.
idea_icon_360034105233.pngidea_icon_360034105233.png  Use quotes to filter lists by exact phrase. For example, "phase 3"
Sensor
Adding a sensor shows the sensor values for the duration you select in a graph widget, or the latest sensor value in a single value widget.
Static value
Select static value to show a single value in a widget, or a horizontal line in a graph widget. You can also use a static value in a calculation as a constant.
Math functions
You can do calculations using Min, Max, Average and Sum in combination.
Max and Min
  • Use the Max function to show the largest value from a set of sensor data.
  • Use the Min function to show the smallest value from a set of sensor data.
Add a single value to show the highest or lowest battery temperature
  1. Click Add widget > Single Value.
  2. Name your widget and go to Choose value >Calculated sensor.
  3. Select either Min or Max.
  4. Use Select sensor to select which sensors you want to monitor and click Save.
  5. Click Add.
  6. Save the dashboard.
Average
Use the average function to show the arithmetic mean of a set of sensor data.
Add a graph widget to show average battery temperature.
  1. Click Add widget> Graph.
  2. Name your widget and go to Add value > Calculated sensor.
  3. Select Average.
  5. Click Add.
The resulting graph shows the mean sensor value for a time interval. A time interval is defined by the shortest pull cycle for the selected sensors.
Sum
Use the sum function to add up all the values for each point in time.
Add a single value widget to show PUE
Calculate the efficiency of specific locations, rooms, etc.
  1. Click Add widget > Single value.
    Add single valueAdd single value
  2. Name your widget and go to Choose type > Calculated sensor.
    Choose typeChoose type
  3. Click Select sensors and search for the sensors representing the total facility power. Click Save.
    Select sensorsSelect sensors
  4. Click Value calculation.
    Click Value calculationClick Value calculation
  5. Use the menu to select Divide.
  6. Click Choose type > Calculated sensor and search for the sensors representing the IT equipment power. Click Save.
  7. Name the value and click Add.
    Click AddClick Add
  8. Save the dashboard.
    Click SaveClick Save
