Available DCO related downloads
DCO
Support for Data Center Operation version 8.3.x ended on January 1, 2022. Upgrade to EcoStruxure IT Advisor.
  • EcoStruxure IT Help Center
  • IT Advisor
  • DCO
  • DCO
  • Available DCO related downloads
  • Mark as Read
  • Data Center Operation (DCO) end of version announc...
  • Data Center Operation (DCO) end of version FAQ
  • DCO 8.3.x user guide PDF
  • How to verify device support in DCO
  • Upgrading to DCO 8.x from previous versions
  • DCO/ITA software download links
EcoStruxure IT Support
Request Support
Back to DCO
  • Mark as Read
Picard EcoStruxureIT
‎2020-02-28 06:13 AM
Want to install or upgrade to the latest version of DCO?
Contact your local Schneider Electric technical support to verify your support contract and get download links. Go to http://www.apc.com/support/contact/index.cfm and select your country/region.
For information about available service packs, genomes, etc., contact technical support.
DCE patch to fix wrong power and current values sent to DCO
This is a version-specific patch that fixes wrong power and current values reported by specified rack PDUs with multiple power banks.
  1. Download the patch: pduSensorUpdatesV2.xml
  2. Follow the instructions to apply the patch.
File to enable RDP linking through custom properties in DCO
You can create an RDP link through the Custom Properties. When you later select the custom property, the system will launch a Remote Desktop Connection for that server.
  1. Download and save the patch: remote.rdp
  2. Open it in Notepad++ or similar text editor.
    1. Replace <HOSTNAME> with the hostname or IP address of the RDP server and replace the port if is running on another port.
    2. Replace <USERNAME>
  3. In Data Center Operation, create a new custom property and set the Value to: file://<PATH_TO_FOLDER>/remote.rdp
    A link that can launch an RDP session has been generated.
The .rdp file is stored on one client, so the link will not work from other clients. To enable the link on multiple clients, store the .rdp file in a shared location, such as an FTP or web server.
